1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#17586 02/14/2003 4:59 PM
Hmmm.... and I wondered why the king pins were so hard to remove and why the steering was so stiff. Maybe it rotated during reaming... :confused:
Kingpin Bushing
#17587 02/14/2003 10:34 PM
That's why I like the bushings with the groove machined all the way around the grease hole so it still gets greased if the holes didn't quite line up right.
Sometimes they twist when the grease dries out in the bore, too. Always keep them well greased.
Paint & Body Shop moderator
#17588 02/15/2003 8:04 AM
Could have been installed in-correctly and when they put it together wondered why it would not take grease eek
#17589 02/16/2003 5:13 AM
Did you have to hammer the bushing to get it out ?? If so then it was just installed wrong .
Make sure the lube hole in the bushing is in line with the grease nipple hole when installing the new bushings . I dont think you should have to ream the bushings either / just what year is the truck ?
