| | | Forums66 Topics128,087 Posts1,055,999 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17586 02/14/2003 4:59 PM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Hmmm.... and I wondered why the king pins were so hard to remove and why the steering was so stiff. Maybe it rotated during reaming... :confused: Kingpin Bushing | | |
#17587 02/14/2003 10:34 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That's why I like the bushings with the groove machined all the way around the grease hole so it still gets greased if the holes didn't quite line up right.
Sometimes they twist when the grease dries out in the bore, too. Always keep them well greased.
#17588 02/15/2003 8:04 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Could have been installed in-correctly and when they put it together wondered why it would not take grease
#17589 02/16/2003 5:13 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Did you have to hammer the bushing to get it out ?? If so then it was just installed wrong . Make sure the lube hole in the bushing is in line with the grease nipple hole when installing the new bushings . I dont think you should have to ream the bushings either / just what year is the truck ? | | |
