| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | Greetings! Today I started the dreaded job of sanding the interior of the cab, namely the firewall. I noticed a seam that goes around the entire outside of the firewall and disappears at the bottom behind some floor panels. Can the firewall be removed? And if so, how?
And about the floor panels on the sides where the toe board screws into and where the dimmer switch is located. How can that be removed? I've got the screws at the top removed, but it looks like they are welded to the floor.
Thanks!
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
| | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | Try a search from the menu bar for "firewall." There are quite a few results there. Bruce Michaels may be able to help you out, too. He painted his firewall and we did a feature on it. Bruce is our Sir Links-A-Lot [email] [email protected] [/email] ... I'm sure he'd be glad to help you with what he knows. Peg
~ One of many.
| | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Too many spotwelds to drill out to make firewall removal an option for me. | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | Exactly Barry, I contemplated removing mine and then repacing it to give it the smooth look. But I did'nt contemplate to long, I decided to remove all the ridges in the original firewall then skinned over it with new metal. It turned out great. It also stiffened up the firewall so I could use a firewall mounted master cylinder. http://www.imagestation.com/picture/sraid150/p0a7f2d0e2ed639c909beac7652844f60/f5daebaf.jpg | | | | | Joined: May 2001 Posts: 49 Member | | Member Joined: May 2001 Posts: 49 | Thanks for the tips! I'll keep plugging away at it.
Charlie
