4 members (Hanks custodian, Bisbee, Eileen, Bill Hanlon), 125 guests, and 3 robots.
Topics128,089
Posts1,056,439
Members48,443
#175856 05/24/2005 1:55 AM
Greetings! Today I started the dreaded job of sanding the interior of the cab, namely the firewall. I noticed a seam that goes around the entire outside of the firewall and disappears at the bottom behind some floor panels. Can the firewall be removed? And if so, how?
And about the floor panels on the sides where the toe board screws into and where the dimmer switch is located. How can that be removed? I've got the screws at the top removed, but it looks like they are welded to the floor.
Thanks!
Charlie
Rustzilla, '41 Chevy 1/2 ton pickup
Try a search from the menu bar for "firewall." There are quite a few results there. Bruce Michaels may be able to help you out, too. He painted his firewall and we did a feature on it.
Bruce is our Sir Links-A-Lot [email][email protected] [/email] ... I'm sure he'd be glad to help you with what he knows.
Peg
~ One of many.
Too many spotwelds to drill out to make firewall removal an option for me.
To be long remembered as he's cruising in
The Passing Lane
Exactly Barry, I contemplated removing mine and then repacing it to give it the smooth look. But I did'nt contemplate to long, I decided to remove all the ridges in the original firewall then skinned over it with new metal. It turned out great. It also stiffened up the firewall so I could use a firewall mounted master cylinder.
http://www.imagestation.com/picture/sraid150/p0a7f2d0e2ed639c909beac7652844f60/f5daebaf.jpg
Thanks for the tips! I'll keep plugging away at it.
Charlie
