7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#1758 08/03/2003 2:19 AM
I have a 58 chevy 1/2 ton long bed step side. On one of the brake drums there is a coiled spring around the outside that sits in a groove near the back edge. The spring is made out of flat steel that is a little larger in diameter than a wood pencil. When off the drum, it is compressed into tight coils.
The other 3 drums have the groove but no spring.
What is the purpose of the spring?
Is it necessary?
If necessary, does anyone know where these can be purchased?
Thanks: confused:
#1759 08/04/2003 1:57 AM
I believe the spring is on there to dampen vibrations. It won't make any difference in the operation of the brakes.
1951 1 Ton Completed
#1760 08/04/2003 3:08 PM
what Nix sez maybe, also maybe heat dissapator - I've seen about 10% of original drums w/ that spring, never on a brand new one - maybe an OEM thing - Cletis would say yer no longer original if ya take it off grin but it'll still work!
