1 members (baldeagle), 105 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#175798 04/02/2005 6:13 PM
I was changing my spark plugs, and here's what happened -
1st plug - take off L-bent wire, take out plug, replace with new plug
2nd plug - take off L-bent wire, take out plug, replace with new plug
3rd plug - take off straight (no bend) wire, and WHAT!? a completely different size spark plug - doen't even look like the other one. Also, the wire took about 20 minutes of pulling to get it off. Now, I can't get my socket on the wire, to pull it out. Is this a problem, that it's different than all the others? I'm thinking this could be why it's making little small backfires.
GO RANGERS grin
Photos Updated so check them out!
#175799 04/02/2005 6:45 PM
not the expert, but if I ran across that I'd suspect a po had put a hotter plug in one cyl to take care of some problem like oil fouling - the socket not fitting just means it's a different size - there's a variety of socket sizes for various plug types/manufacturers - the lack of elbow on the wire just means that one wire was replaced seperate from the set, or maybe it just fits the space easier that way - if plug wires don't come off right away, try twisting first to break it loose, then pull
#175800 04/02/2005 6:51 PM
Alright, I'll do that. I'm kind of worried that the wire might be too big for the new plug...hopefully not
Thanks bill
-stephen
GO RANGERS grin
