| | | Forums66 Topics128,193 Posts1,057,363 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | hiyas folks.
so, I have my old '65 chevy truck... old everything... but the truck sits around, under or near several trees. Pine trees, big holly trees, oak trees mainly... and it gets this black powder dust junk on it and it is a pain to get off.
Also, I have a few grease/grime hand/fingerprint spots I got on there and I need to get off.
Any suggestions? tried my auto washing soap... dish washing soap...
I'm not much into washing my truck very often but it got pretty dang dirty... so something had to be done, heh.
Any tips, tricks or product recommendations appreciated.
thank you,
-W | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | ZEP degreaser will do the trick.Used it on my camper setting under trees.Just spray on,let it set for 10 min,scrub off with brush,hose off.Great stuff,don't use on alum
dan-pa
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | W, if you have an old paint job on it, what you can do is take a Scotchbrite pad, car soap, warm water, and a rag and that'll scrub that crap right off. Your truck will be nice and clean afterwards. Then, if your truck has a nice patina to it, take some 0000 steel wool to your now-clean truck. Makes it look nice without spending billions on a detail.
Even makes primer spots and weak paint areas look good!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | in my area its called pollen but its green. this time of year you can have any color and in a short time it will have a lime look. the black stuff may be dust mixed with pine sap. which can be hard to get off. if there are localized globs of it bug and tar remover does well. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Bug & Tar remover works well.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I used a Scotch Brite pad to remove overspray. Make sure if you use one though, get the non scratch blue pad. The green or red will remove your paint as well as the crud.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Prior to painting I used to wash the dingy white paint using Tide and 2-3 cups of bleach in the wash water. Would use a scrub sponge (scotchbrite) and rinse well. Real bright white when finished. Don't imagine this would work all that great on pine tar etc but would cut the grease, oil, and stains pretty well.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | In the 1950's a painter I worked with told me to pour a cup of kerosene into water with some soap to clean off a really dirty, stained truck I was working on. I have done this many times since with success. The first wash job on my 54 6100 was as I have described and 20 years of grime disappeared. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | hey Woog,,The stuff on my old international is green, I would just leave it as is ,,,,, protects the paint that way.  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | .....dont park the truck under the trees...... | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Good old hot water & TriSodium Phosphate, TSP, cleans anything off of anything else. Brian | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | ooh - I have some tsp 'substitute' - forgot I had it - mebbe I should try that. scotch brite pads, bleach, tide... kerosene... wow. good stuff. as for the many suggestions I've had here and elsewhere to cut down the trees or don't park under the trees... neither is an option... I like trees and there is nowhere else to park. Thanks for the replies! -W | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Good ole BRAKE FLUID will to the trick.
Years ago I was into buying computer equipment from sealed bid goverment auction thru the GSA.. lots of excess stuff from the 2000 census, mostly.. altho there were some cool gadgets that came out of NOAA.
Anywhoo.. the goverment is fond of writing on things with a big fat permenent magic marker.. which can really knock a few dollars off the resale value of this stuff on eBay, so I was using just about everything I could try.. from choke and carb cleaner, to simple green and mean green.. the stuff ended up comming off, but it took some work.
As luck would have it, I was picking up a buddies car from the garage and I saw a guy whiping road paint off the side of a customers car. Now, road paint is some heavy duty paint.. and this guy was taking it off with little to no effort.
Despite the sign that read "No customers in the garage area" I just had to know what he had in that big white bottle.. it was plain old brake fluid.
I went back to my office (after a pit stop at Auto Zone) and gave it a try, and it worked great.
Since then, i've used it to take all sorts of crud and marks off of lots other stuff.. even tree sap dripped on a nice new car.
If you own a Stovebolt, my guess is you've already got some brake fluid around the house.. try it on a small spot and see what you think!
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Doesn't brake fluid eat paint?
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | You know, I would have thought it might.. but I guess the secret is to wash the truck with conventional methods after the tough stuff is off.
On the same token, a direct scrub with brake fluid on a plastic computer monitor cleans marker right off, with no discoloration.. but plastic is alot different than a fresh new paint job, so i'd use caution when using it on anything real nice.. maybe try a small spot and make sure it's not going to eat or otherwise jack up your paint job.
| | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | All of you are crazy. If you have nice paint or you are trying to keep what may be left I would not use a brush or bleach or any of that stuff.
Go buy some clay magic. It will take it off. Macguires also makes a clay product that should work and wont ruin your paint. It is a lot of work though so I dont reccomend it if you don't want to spend the time to do it. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | If all else fails just reach for the go-jo,all stovebolters have some siting around.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
