8 members (Gdads51, 1955 1 Series, 68ironhead, PAUL Berardi, Joe H, 3B, Jon G, JW51),
154
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Hi all, I located an engine and transmission that I am interested in buying. It is located in Texas and I am in So. Calif. Can anyone tell me the weight for a 327 SBC with a 350 transmission attached. Also, if anyone has done this before and can reccomend a transport compamy I would like to hear from them. Thanks, Don | | | | | Joined: Mar 2003 Posts: 315 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 315 | Freightquote.com can you give you quotes on shipping rates from several freight companys. I just used them to have an engine shipped to me. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I agree with Dunfire. We use freightquote.com daily. Make sure that the company that you choose has a facility in the location that the engine needs to be picked up and where you need it delivered. I shipped an air compressor from Amarillo, TX to Tipton, CA that took 32 days to get there using Southwest Motor Transport. Try to stick to a well known freight company like ABF, FedEx Freight, Central, Roadway, ect.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | The 327 V8 (long block)weighs @ 575 lbs. | | |
