1 members (UtahYork),
108
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17542 12/30/2003 9:55 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Enough with the acronyms!
I was wondering which header fits best in a 59 apache with a Chevy small block and side motor mounts.
I was thinking Headman street rod (block hugger type) or the street header.
Any suggestions? TIA
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
#17543 12/30/2003 11:45 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Ryan-
Greetings from NH. Can't stay away from the Stovebolt! When my bro-in-law put a 350 in his S-10 Blazer, Headman's were the only way to go to clear the steering box and hug the block. This is a good option (plus I can arrange a look-see if you're interested).
If you have room, you can save money with some salvaged stock GM products instead. What's important to you, look or $$? | | |
#17544 12/31/2003 7:37 AM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Phil,
Snow here - and cold. Enjoy NH!
I'll grab the block huggers unless I hear otherwise on the BOLT. If they won't work - then I'll figure something else out. Thanks for the hint.
Give me a call when you get back into town. I'll grab the steering column.
- Ryan
#17545 12/31/2003 10:51 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | There are two styles of ram horn Small block chevy manifolds 2wd pickups have the angled back center dump style and the 4x4`s use straight down dump (similar to the corvette ram horn manifolds) - Scroll down to the 324, 324-c, 695-L. and 743-R manifolds on the left of the page - http://www.stevensparts.com/CHEV%20EXHAUST%20MANIFOLDS.htm
#17546 12/31/2003 1:30 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Ryan: Had to do a little digging, (Chevy High Permormance Mag.) They rated HPC (High Permormance Coatings) block hugger headers as very good header. They are very short but where room is a premium they work exceptionally well.
Also a indication which I like is .400 thickness flange compared to .300 for budget headers. HPC phone 801-262-6807
popcorn The Truth is Out There (Hope I helped) | | |
#17547 12/31/2003 6:11 PM | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Thanks for the ideas!
I'll post pics as to the result....
- Ryan
#17548 12/31/2003 8:27 PM | Joined: Sep 2000 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2000 Posts: 136 | Ryan- the 350 in my 57 presents the same problems you are facing. My first choice were the stock manifolds which drop below the plugs, what I learned as Chevelle-style manifolds. Great on the drivers side, but on the passenger side the manifold dumps directly into the crossmember, so I nixed that plan. I bought a pair of block-huggers from Summit Racing, but discovered that I can barely slide a dollar bill between the starter and the header collector flange. Plan C is a different set of headers which drop straight down from the heads, and discharge under the transmission cross-member. Looking for recommendations from the audience. | | |
#17549 12/31/2003 8:43 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Russell: The HPC's do that the exhaust center is straight down between 2&3 spark plugs. Then you can bring the exhaust pipe up to it but below the transmission crossmember. I haven't got that far on my 59 but hope to have engine installed this spring then I'll know more about the subject.
popcorn The Truth is Out There (Good luck guys) keep me posted so all the worry will be gone! | | |
