2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#17542 12/30/2003 9:55 PM
Enough with the acronyms!
I was wondering which header fits best in a 59 apache with a Chevy small block and side motor mounts.
I was thinking Headman street rod (block hugger type) or the street header.
Any suggestions?
TIA
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
Ryan-
Greetings from NH. Can't stay away from the Stovebolt! When my bro-in-law put a 350 in his S-10 Blazer, Headman's were the only way to go to clear the steering box and hug the block. This is a good option (plus I can arrange a look-see if you're interested).
If you have room, you can save money with some salvaged stock GM products instead. What's important to you, look or $$?
Phil,
Snow here - and cold. Enjoy NH!
I'll grab the block huggers unless I hear otherwise on the BOLT. If they won't work - then I'll figure something else out. Thanks for the hint.
Give me a call when you get back into town. I'll grab the steering column.
- Ryan
59 Apache Step
78 El Camino
There are two styles of ram horn Small block chevy manifolds
2wd pickups have the angled back center dump style and the 4x4`s use straight down dump (similar to the corvette ram horn manifolds)
Scroll down to the 324, 324-c, 695-L. and 743-R manifolds on the left of the page
http://www.stevensparts.com/CHEV%20EXHAUST%20MANIFOLDS.htm
Ryan: Had to do a little digging, (Chevy High Permormance Mag.) They rated HPC (High Permormance Coatings) block hugger headers as very good header. They are very short but where room is a premium they work exceptionally well.
Also a indication which I like is .400 thickness flange compared to .300 for budget headers. HPC phone 801-262-6807
popcorn The Truth is Out There (Hope I helped)
Thanks for the ideas!
I'll post pics as to the result....
- Ryan
59 Apache Step
78 El Camino
Ryan- the 350 in my 57 presents the same problems you are facing. My first choice were the stock manifolds which drop below the plugs, what I learned as Chevelle-style manifolds. Great on the drivers side, but on the passenger side the manifold dumps directly into the crossmember, so I nixed that plan. I bought a pair of block-huggers from Summit Racing, but discovered that I can barely slide a dollar bill between the starter and the header collector flange. Plan C is a different set of headers which drop straight down from the heads, and discharge under the transmission cross-member. Looking for recommendations from the audience.
Russell: The HPC's do that the exhaust center is straight down between 2&3 spark plugs. Then you can bring the exhaust pipe up to it but below the transmission crossmember. I haven't got that far on my 59 but hope to have engine installed this spring then I'll know more about the subject.
popcorn The Truth is Out There (Good luck guys)
keep me posted so all the worry will be gone!
