1 members (TIM ZINDLER), 104 guests, and 5 robots.
Topics128,269
Posts1,058,403
Members48,485
As you all know our trucks use to run on leaded gasoline. My truck was parked before they switched to unleaded gasoline so it has never run on unleaded gasoline. What are the effects of running Unleaded gasoline in an engine that was designed to run on leaded gas? thanks
You may or may not have a problem with the softer valve seats. If you're getting the engine rebuilt, I'd have hardened seats installed...if not, I would just drive it and see how it goes. Some of the more experienced mechanics will probably chime in here with better explanations. cool
1954 GMC De Luxe COE
run her til she drops. tetraethyl lead (big word for a brokedown cop) was used more as a lubricant for the valves, as i understand it. in time, the valve seats take the brunt of the damage. this ain't an overnight thing, so personally iwouldn't worry about it. you can buy a replacement product from aftermarket stores, but personally-------aaaaaaah, why bother
The way I filtered out this is....
If you are running a in-line 6 (low rev. motor), no worry. Even the manufacturer of the additive says it is not needed. On the other hand, if you are running a V-8 (higher rev. motor), it will be a problem WAY OUT in the future. I rebuilt a 283 V-8 and had the hardened seats put in at that time. I don't think it is worth a head rebuild just to do seats.
Drive it and put in additive if it gives you peace of mind, its not much $$$$
Others will chime in.....
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
I'm as much a VW nut as old truck nut, so here's my .02: It makes a huge diffence on an air cooled engine, where the seats are right on the edge of burning up. For a water cooled beast, the problem is minimal, except in extreme conditions like really lean fuel/air mixtures and advanced timing. Just wait till head rebuild time in the future and consider upgrading then.
'53 chevy 3/4 ton
You can buy a lead additive at most auto parts stores.It is not expensive.
Thanks guys, i just wanted to make sure my engine wont blow up when i start it or it would do serious internal damage.
