1 members (stlcardinalsguy), 115 guests, and 3 robots.
Topics128,195
Posts1,057,374
Members48,469
#175202 02/16/2005 12:49 AM
i can't find anyting searching around... what brake fluid should go in my 52 3/4 ton?
dot 3 or dot 4? there are dot 3/4 compatible ones out there i've used on other vehicles.
anything special here?
thanks
-bryan
#175203 02/16/2005 2:36 AM
I use dot3. The 4 is a higher temp, and compatible, but the higher boiling temp doesn't matter on these trucks. There is also Dot5, silicone base, which doesn't absorb water. To use it you need to replace all of the rubber in your system. Dot5 also is a bit more sluggish, so some don't like it.
Fred
52 3600
69 C-10
#175204 02/16/2005 5:21 PM
thanks fred
dot 5 also turns to sludge when combined with standard fluid. maybe if i did a complete rebuild.
and now to bastardize my own thread.... how about the differential and transmission?
standard 90wt?
gl4 or gl5 in the trans
-b
#175205 02/16/2005 6:36 PM
Straight 90 or 80W-90 in the differential and tranny.
Steering gear, there is a special lube available, but per GM you can use chassis lube, I prefer the moly base since it does better at lower temps. If you put gear lube in, it will leak out in a hurry.
For the hood badges, go to some of the on-line vendors and look around. There are also some tech pages that spell out the year differences, I think on this board and at some of the vendors. There's also a website about old Chevy trucks that lists all the differences. Think there was a thread about it at http://chevygmcofkc.org/
I hate to cut and run, but it's a zoo here at work right now.
Fred
52 3600
69 C-10
#175206 02/16/2005 9:44 PM
on the break fluids.Don't mix silicone & reg break fluid.If your driving daily the reg fluid is fine.If truck is setting for months at a time,use silicone break fluid.Remember water will pit the break wheel cyclinders.Silicone cost more,but in the long run will save you $$$$$.I use silicone and have seen no difference in the breaking of my truck,stopping.
dan-pa
#175207 02/16/2005 9:47 PM
Quote
i guess i can do my own research grin
thanks
#175208 02/16/2005 10:02 PM
One of the things I really like about DOT 5 is that it doesn't remove paint like DOT 3 does.
Gord
1954 1/2 ton 235 4 speed
#175209 02/16/2005 11:14 PM
Quote
"I'm up to my ears in alligators."
Sittin' Pretty in My Old Kentucky Home.
http://www.picturetrail.com/barneysbowtie
#175210 02/17/2005 12:01 AM
Quote
good point, but if you know what my truck looks like removing paint isn't a bad thing grin
#175211 02/19/2005 4:09 AM
Anonymous
Unregistered
Anonymous
Unregistered
^^^^^ hehe, I hear ya....
