1 members (PullG),
40
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | could someone with a 47-54 1/2 ton give me the approx. distance from outer edge of frame to center of king pin on driver's side (suspension on ground)??? I need to compare this to my 3/4 ton for steering upgrade. MANY THANKS
'53 chevy 3/4 ton
| | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Don't know the dimension you need but the frame width should be 28" at the centerline of the front axle. I would venture to say if you measure the center to center of the king pins, then took one half of that minus 14" (1/2 half the frame width you would have the answer. Just a suggestion. Neither my assembly manual or shop manual give the axle measurement.
Good luck.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
| | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | thanks- what I need is the horizontal dimension from king pin center line to outer edge of drivers side frame rail........ I need to know if it is close to 3/4 ton dimension. I'm trying to figure out if power steering upgrade kit (made for 1/2 ton) will work on my 3/4 ton.
'53 chevy 3/4 ton
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | I measured approx 10 7/8" from center of top kingpin plug to frame where axle crosses it. (I held a straight edge against the frame so the measurement is near to horizontal)
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | thank you everyone for helping me out. This is a great place to get advice. I really appreciate your taking the time to give a fellow truck guy a hand. thanks thanks thanks
'53 chevy 3/4 ton
