1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17509 01/29/2003 8:56 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, I got a few questions. When does the vacumm advance work on the distributor, and how do you check to see if it's not working? If the VA is fine, what would cause pour vacumm? Also how do you use the dwell on the 235?
My truck don't leak oil, it just marks its teritory.
#17510 01/29/2003 6:01 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | vacuum advance, you can watch it move when the engine is revved. And you can check the module by gently sucking or blowing in it. Don't do either very hard, you will crack the diaphragm.
Dwell should be about 32, I usually set with a feeler gauge then check with the meter. V8s were easier, they had a window in the cap to set the dwell. Usually takes a couple of times to get reasonably close.
Do you have a vacuum gauge? It is a big help in tuning these non-computer engines. If your vacuum is low overall, check for leaks, either hoses or intake manifold.
Fred 52 3600 69 C-10
#17511 01/30/2003 8:35 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Fred T, The vacumm advance on the distributor isn't working. I think i'm gonna have to replace it. I checked the vacumm line. I do have vacumm, but it isn't alot. Should there be alot of vacumm on a 1962 235? I located a small exhaust leak on the #1 cylinder exhaust manifold. Would that cause low vacumm? Also how much is a new manifold gasket, a exhaust doughnut gasket, and new manifold bolts?
#17512 01/30/2003 8:01 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You should have low vacuum at idle at the vacuum advance but it should shoot up to about 15-17 lbs when you rev the engine up to about 1200 rpm.
#17513 01/30/2003 8:59 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | The easy was to set the dwell is : remove the plugs then adjut it whilst spinning that starter . more accurate and way faster that way .
if the dwell varies by more than 3 degrees when you rev. the engine , the dist. bushings are shot - time for another one , Pomona is March 2nd.
I recall you're in the SGV , go to NAPA on Truman in SF and ask Dave or Sue for NAPA Gasket # MS12185X tell 'em Nate sentcha for a discount .
When re-tighening the manifold to the head , start in the center and work your way out , this will prevent future leaks .
Should be _no_ vacuum at the dizzy @ idle , 18" ~ 21" at the manifold . retarded timing can cause low vacuum readings .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#17514 02/02/2003 3:34 AM | | Anonymous Unregistered | | Anonymous Unregistered | I " recall " you also Volkswagen Nate. Is your truck running HOT !!! I though you moved over to the " Old chevy Truck " section ?????????? | | |
#17515 02/03/2003 10:46 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Hi MT , no it never runs hot , even in Death Valley it keeps it's cool :-) . I had a custom oversize core installed in an original '49 radiator , I gotta find the time to install it though - it pukes excess water out the tiny header tank I have in there now .
I get hasseled for being here (work) so I can sneak on the other list more easily - hope you all are doing well .
