1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
Junior Member
Junior Member
I will like to lower my 55 1st series, by using lowering blocks in the back and the front.
I have access to 1955 second series lowering blocks, will they work for my 1st series truck?
i made my own out of square steel tubing same material they use for frames. got at a steel fabricating supply yard. they cut it to size and i drilled the holes and installed the locating pins. used them for 20yrs until last summer i replaced the rear axle and front to IFS. only answer i have for you. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Won't work in the front, it's spring over axle.
Paint & Body Shop moderator
