| | | Forums66 Topics128,120 Posts1,056,319 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | I'm helping my brother work on his 56 1 ton and the brake pedal doesn't return all the way leaving the brake lights on. I doubled up the return spring and greased the pivot with no help. If feeling like the pedal is binding up at the pivot. Can they be rebuilt?? If so where can I get parts.
John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe it's binding a bit on the floor hole? I've had one do that - they get pushed sideways sometime w/ age because no one ever pushes straight down
if it is the pivot on the master cyl, it could be the pin worn, or the eye on the plunger is a bit oval from years of not being greased, so you'd have to take it apart and see - don't know of anyplace those bits can be found except good used, or you could clean it up w/ some weld and reshapeing
Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I'm having the same problem John. I'll let you know if I come up with anything! | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I had the same problem with my 55.Turned out to be padal was rubbing on the carpet.I tried exrta springs,lubricating everything 3 or 4 times,and finally found the carpet was the culprit. | | | | | Joined: Feb 2005 Posts: 19 Junior Member | | Junior Member Joined: Feb 2005 Posts: 19 | Thank everyone for the information. I plan on taking the pedal assembly out and going thru it. I removed the felt and rubber seal in the floor to eliminate a potential cause but I still have the problem. The master cylinder is new. Jim Carter Parts has a clutch/brake pedal bushing kit for 20.00. If your interested I will let you know how I make out.
John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | let us know fer sure - I'd be interested in what the kit is if ya get it - the clutch and brake pedal arms are totally separate assemblies, unlike some previous years, and I can't think of anyplace they have common or even similar places for bushings
Bill | | |
