4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 107 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#174722 03/07/2005 10:33 PM
i was tryin to start my truck up today and it was grinding... sounded liek i think the starter.. any short term/long term solutions?
Not sure what kind of sound you are talking about. If it is just not turning over good it could be the battery. If it sounds like gears grinding it could be the starter bendix grinding on the ring gear.That can ruin the ring gear. Big problem if not fixed soon. Good luck.
I like old trucks
MIke What year is your truck? Is it an foot pedle starter or Key? That may make alot of difference.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
its a 1961.. starts with a key.. although just the othr day it started up with no grinding.. wierd deal
check if the starter mount bolts are loose - if they loosen a bit the starter can torque around so the gear isn't engaging well - don't ask me how I know grin
I would also check to make sure you have a good ground. Battery to frame and then frame to motor.
Brian Moore
