3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#174600 12/01/2004 12:35 AM
I need a little help. I have a '51 1/2 ton and I've disassembled the steering linkage and found that the relay rod has a bow in it. Should it have a bow or should it be laser straight? Can it be used in this condition? If I roll it on a table it has about a 1/4 to 3/8 inch bow at the highest point. I'm in the process of reassembly and installing the ball studs on the linkage. It's nice to be putting things together for a change. Thanks for any help.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
#174601 12/01/2004 1:23 AM
Relay rod? Do you mean the drag link, from the steering gear to the axle? I believe it needs to be straight, to allow the steering grear to center-point correctly. Fortunately, a few gentle taps with a BFH will straighten it!
#174602 12/01/2004 1:36 AM
HotRod:
I thought it was called the relay rod. It goes from one wheel across to the other wheel. Is this called the tie rod? Anyway, should it be tapped back straight with the infamous BFH?
Thanks.
Mark
1951 Chevy 3100
#174603 12/01/2004 3:19 AM
I picked up a 53 front end from a guy who did a clip and the tie-rod was bowed. It is not a solid rod but seems to be built from steel tube.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#174604 12/01/2004 4:07 AM
a bent tie rod is not a good thing, and if straightened will prolly bend again, or break someday - frequently the result of things like bad kingpins, overtight rod ends [not lubed for years] and fat passenger car tires - replace it, or add a piece of angle iron to it [farmers use a chunk of old bed frame grin ]
#174605 12/01/2004 12:08 PM
Hey Guys-
Thanks for the answer. I'm off to find a good one.
Mark
1951 Chevy 3100
#174606 12/01/2004 11:24 PM
Riding in the Passing Lane
What you are refering to is a tie-rod. They
ussually get bent by someone using a jack on
the axle. No more out than you describe it can
be straightened. smile
1972 Chevy c10 Cheyenne Super
#174607 12/02/2004 12:33 AM
Thanks Wrench. I really would like to keep it. I'll try and staighten it.
Mark
1951 Chevy 3100
#174608 12/02/2004 2:26 AM
Moderator
Moderator
I like the chunk of bedframe idea.
I saw a guy bend a tie rod popping over the top of a gully in a Jeep CJ5 with a souped 350. That thing was so pigeon toed that we took the tie rod off right there...
But that's a story for the off topic thread...
Next time I saw the guy he had a piece of angle iron welded on it. Busted a tie rod end that day...
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
