9 members (MickeyP, TexasJim50, MRMEROTH11, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible), 117 guests, and 2 robots.
Topics128,132
Posts1,056,378
Members48,441
Does anyone know how much coolant a 305 V6 takes? Every time I put anti-freeze and water in it, the ratio is always off, and the stuff turns into slush in the engine. thanks.
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
Slush? Frothy brown slush? Sounds like you are getting oil in there. Coolant never turns to slush in any water/antifreeze ratio.
I always mix my coolant before I install it in an extra container so I always get the correct ratio.
[ 01-30-2002: Message edited by: 4ontheFloor ]
Paint & Body Shop moderator
Mixing coolant in a separate container does not always insure the proper ratio.
If the cooling system was flushed with water, you can be assured there is still some water left in it. If you just fill it up with 50/50, and there is still pure water in block, your solution will be diluted (granted it's only a tiny bit).
Now, of course I don't really care anyway, and just fill it up with 50/50. Just make sure you check the freezing point with an antifreeze tester.
Here in VA it doesn't really get that cold, so I just gotta worry bout down to a little bit below freezing.
Jay
People don't understand why I love old trucks...could it be cause i'm 17?
'54 3800 dually
http://www.dpsolutions-inc.com/54truck/truck.jpg
'56 GMC Dump Truck (and story)
http://www.dpsolutions-inc.com/56dump
nope its not brown and frothy. Its still as green as it ever was. Since I dont know the coolant capacity, its kinda hard to tell the right ratio. I should probably put two gallons of anti-freeze in and fill the rest with water. The temperature around here dipped last night to around -6 degrees.
Jonathan S. Keffer
