| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 734 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 734 | The '67 has some glass scratches that really don't warrant replacement of the whole glass. I'm thinking of wet sanding with 800 grit then progressively finer up to 1500 then polishing. Is this an accepted technique? Anyone have any tips or hints?
Matthew 6:33 1952 Chevy 1/2-ton 3100 Late '55 235/SM420/torque tube 3.55 Dalton Highway survivor (using original 216) www.truckwithaheart.com | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Scott when I worked for Pep Boys we had a Glass polish you might try this first. Good luck!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Why don't you do a google search? I think the sandpaper would scratch the glass up so bad you would never be able to polish the scratches out again. One time I had a special half round piece of glass made for a special job. I had made the frame myself by laminating thin plywood to that shape. They hadn't cut the glass exactly right and I had a little trouble fitting it to my frame. So I though to sand the edges a little. Regrettably I must have touched more than just the edge because afterwards there were some scratches visible. I used everything including special glass polishes and a power buffer and never got them out.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Aug 2001 Posts: 139 Member | | Member Joined: Aug 2001 Posts: 139 | Scott, we have a company in town that is probably known world wide, in avaiation cicles that is. Micro-Surface Finishing Products Inc. You might go to IceRocket.searchengine and do a search. Bet you will find them. Don't know how much help you might find on their web site. I have an article on doing what you want to do, but I don't know where it is. Myself I would use an old piece of glass to experiment before I touched my truck. Good luck. Mike | | | | | Joined: Mar 2004 Posts: 14 Junior Member | | Junior Member Joined: Mar 2004 Posts: 14 | Try this link to Eastwood Company or go to www.eastwoodco.com and search for "glass polish" http://tinyurl.com/6mn4l Tim Bowers Stellar Antique Auto Restorations Windom, KS
Tim
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | About six months ago, Cars and Parts had an article where they actually did a windshield. In the end, the windshield was "improved", but the scratches were still visable. They said in the article that they could have gone further, but at the risk of creating a visual distortion in the glass. | | |
