0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17412 02/03/2002 4:56 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | I've got a 52 1/2 ton with a Camaro rear and stock springs. I have the rear end off;I'm putting in new shackles and U-bolts over the axle. My question is:With the spring perches allready welded on the axle tubes and you tighten every thing up,how do you adjust the pinion angle? The PO did the swap,and it drives just fine the way it bolts-up.Am I just lucky? The spring perches are stock Camaro. | | |
#17413 02/03/2002 5:35 PM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | You can use shims like they use to align the front end. Angles should be close to parallel, or the pinion a couple-three degrees down from to being paralle, but I might leave it alone if it's close and working fine.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
