3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#17412 02/03/2002 4:56 PM
I've got a 52 1/2 ton with a Camaro rear and stock springs. I have the rear end off;I'm putting in new shackles and U-bolts over the axle.
My question is:With the spring perches allready welded on the axle tubes and you tighten every thing up,how do you adjust the pinion angle?
The PO did the swap,and it drives just fine the way it bolts-up.Am I just lucky? The spring perches are stock Camaro.
#17413 02/03/2002 5:35 PM
You can use shims like they use to align the front end. Angles should be close to parallel, or the pinion a couple-three degrees down from to being paralle, but I might leave it alone if it's close and working fine.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
