4 members (walter74, Otto Skorzeny, Ponchogl, Cosmo), 103 guests, and 1 robot.
Topics128,049
Posts1,055,634
#174059 02/19/2005 1:43 AM
I have another question for the experts. Below is a (link) photo showing 1/2ton chevy steering conversion using 80s box and new steering arm, adjustable drag link. The steering arm attaches to knuckle with 2 bolts on either side of king pin. I know the photo is hard to see, but can someone tell me if the 3/4 ton would have the same distance between the 2 mounting holes?? I can measure my 3/4 ton if someone out there with a 1/2 ton could do the same. This will tell me whether I need to modify the steering arm which comes with the kit for my 3/4 ton. Thanks.
http://www.classictruckshop.com/images/tri.jpg
'53 chevy 3/4 ton
I measured 3 1/8" between those holes. The calipers for my disk brakes are attached with bolts that go through the same holes.
Gord
1954 1/2 ton 235 4 speed
that's EXACTLY what I need. Thanks very much... I'll check mine to see if its the same. Thanks again!!!!!
'53 chevy 3/4 ton
