8 members (51sub, 55shaker, Hotrod Lincoln, mason86, Paul Mullen, Peggy M, walter74, Bill Hanlon),
78
0
Mod | | | Forums66 Topics128,050 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I'm puting a residual valve into my breaking system. Some of the parts use pipe threads. What kind (if any) of thread sealer should I use? :confused:
if it dosen't need fixed, break it
| | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | You do not use thread sealer anywhere in a brake system. There are no pipe threads anywhere in a brake system - all fittings are flare nuts - all flares are 45 degree double flare.
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You may also encounter banjo fittings, which require copper crush washers.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Sorry guys its a Wilco residual valve and it does have 1/8 pipe threads on both ends.
| | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | brake fluid will eat teflon tape, at least soften it and make it gooey, so don't use that. i don't have any advise other than that. maybe loctite makes something that would work, kinda doubtfull though. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | Oh yeah, forgot about the banjos... You will need pipe thread to flare adapters. Have a read: Disk Brakes
| | | | | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | I called loctite they gave me a striaght answer to a simple queston recomending 565 sealant. Now I need to find some.
