3 members (Steelonsteel, Patina 54, CandoBrent), 42 guests, and 3 robots.
Topics128,034
Posts1,055,440
Members48,422
#174030 03/03/2005 12:56 AM
I'm puting a residual valve into my breaking system. Some of the parts use pipe threads. What kind (if any) of thread sealer should I use?
:confused:
if it dosen't need fixed, break it
#174031 03/03/2005 5:50 AM
You do not use thread sealer anywhere in a brake system. There are no pipe threads anywhere in a brake system - all fittings are flare nuts - all flares are 45 degree double flare.
Gord
1954 1/2 ton 235 4 speed
#174032 03/03/2005 9:18 AM
You may also encounter banjo fittings, which require copper crush washers.
Paint & Body Shop moderator
#174033 03/03/2005 12:59 PM
Sorry guys its a Wilco residual valve and it does have 1/8 pipe threads on both ends.
#174034 03/03/2005 6:30 PM
brake fluid will eat teflon tape, at least soften it and make it gooey, so don't use that. i don't have any advise other than that. maybe loctite makes something that would work, kinda doubtfull though.
#174035 03/03/2005 7:46 PM
Oh yeah, forgot about the banjos...
You will need pipe thread to flare adapters.
Have a read:
Disk Brakes
Gord
#174036 03/04/2005 11:01 PM
I called loctite they gave me a striaght answer to a simple queston recomending 565 sealant. Now I need to find some.
