1 members (BC59), 211 guests, and 2 robots.
Topics128,087
Posts1,056,106
Members48,434
#173830 09/15/2004 1:11 AM
Hello all, This is only the second time I have posted a message. I finally got my one ton running on the new home made gas tank. It runs fine. Made the tank out of a water pressure tank. I am now trying to get the brake lines loose from the master cylinder so I can rebuild it. While I was working on the gas problem I discovered a bad leak in the brakes. Using lots of PB Blaster and being patient. Got one line loose yesterday. I dont want to twist the fitting off.I am 65 years old so I worked on a lot of this stuff when I was a kid. Fifty years of rust takes time. Trucks and men both.
I like old trucks
#173831 09/15/2004 11:40 AM
Welcome to the Stovebolt Page, Bullet!
Sounds like you found that brake leak via the preferred method (as opposed to the "while driving" method which is generally to be avoided... smile )
Have fun with your truck and be sure to let us know how it goes. Plus, sounds like you have plenty of experience to share with those of us who don't have a clue.
Thanks for being here -- we hope to "see" a lot of you!
Regards,
~ One of many.
