5 members (Denny Graham, Steelonsteel, 66flea, treegrower, Otto Skorzeny), 52 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#173664 12/02/2004 1:41 PM
I see a lot of guys here question the durability of splash oil 216/235 engines,so here's a story on my experience with them in real life.
When I got out of the Army in 1968,I took a temporary truck driving job while waiting to get into the electrical union apprenticeship.
I was hired to haul food scrap from a canning plant to the landfill,heavy sloppy stuff like fruit rinds and such.The truck was a 1950 or so Chevy 6 wheel dump,probably a 2 ton with either a 216 or 235 ,but for sure it was a splash oil engine.The truck had a 5 yard box,loaded up it grossed around 17,000 lbs.Quite a load for 100 hp with a 4 spd and 2 speed rear end.
It was a 40 mile round trip to the mega landfill at the New Jersey Meadowlands, some hiway, mostly hilly secondary roads.I drove the truck wide open against the governor(3100 rpm) in all gears,rowing the gearshift lever and splitting the gears with the 2 speed rear.And I mean 90 percent of the time the pedal was to the floor. Once at the dump,the truck strained in low gear through the mess of rotted garbage and bedsprings,dump the load,then wait for a landfill dozer to push you out onto hard ground.
I made two trips a day for about 4 months before the engine started knocking.The mechanic dropped the pan,I helped him adjust the bearing shims.The second time the knocking started at about 2 months,I drove it with the knock for a week until it really started pounding.This time the mechanic pulled the engine and put in the replacement engine he had ready,another splash oiler.
It was about this time the union called,so I said goodbye,the mechanic sure didn't miss me wink
#173665 12/02/2004 2:38 PM
nice story,,boy I bet the hogs would have loved to to had that stuff grin
Redryder pix
My Hotrod
#173666 12/02/2004 3:42 PM
...and 36 years later you're still replacing engines in old Chevy trucks grin Aren't you alittle hard on these trucks? :p
To be long remembered as he's cruising in
The Passing Lane
#173667 12/02/2004 5:16 PM
I hear how good these engines are in many stories. How many don't end in:
"And after 20 years we put in a fresh battery and gas and she fired right up"
54 3100 with 235
62 flatbed dump C60 with 261
