Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (55shaker), 42 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#173626 10/22/2004 6:00 AM
Junior Member
Junior Member
Can anyone out there tell me what the triangular shaped plate riveted to the outside of the framerail directly above the rear axle is for? Mine had rusted through on one side and the other side had about a 5 inch crack along the bottom of it, so I torched the rivets, popped the plates off and welded a pair of plates on to strengthen the frame. Now I'm sitting here wondering if I made more work for myself down the road. This is on a '54 3100.
Thanks for any help...
Sody It was to hold rubber bump pads. Your axel tubes would hit these if you maxed out the springs and overload springs. If you dont plan to "load" it down you should be fine. Ray
Junior Member
Junior Member
Ok...I was kind of wondering if that's what they were for.
thanks,
I thought them thangs were johnson rod mounts.
Another quality post.
Real Trucks Rattle
Here's a link to a pic with the bumpers in place, Sody
Rear axle bumper and bracket
BTW, Rusty, Johnson Rod Mounts are held in place by Self-sealing Stem Bolts, not rivets grin
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
