2 members (Gray_Ghost, 1 invisible), 238 guests, and 2 robots.
Topics128,106
Posts1,056,213
Members48,436
#173608 05/30/2005 10:56 PM
I have a 57 chev pickup, heavily modified with 305/auto/ps/pb, etc. Getting hot here in central NC and thinking air conditioning. Have seen the vintage air setups for $1000-which look fine but awfully darned expensive.
Has anyone installed an 'old' (read salvaged and repaired) ac system into a fifties pickup? Looking for a probably 1960's setup small enough to fit under dash.
Thoughts?
#173609 05/31/2005 12:16 AM
Every air conditioning install i've seen in those old trucks was either expensive and labor intensive, or cheap and even more labor intensive.
I don't see why you couldn't rip a functional AC unit out of a later model vehicle and rig it in there.. anything can be done in your price range when you have the will the skill, and the ingenuity.
#173610 05/31/2005 12:20 AM
smile
One problem with the "old", salvageable units is most of them use Freon 12. In addition, depending on the age, the hoses may well be on their way to rotting and not the right length. If you get a unit with any age, thus at a cheap price, the unit will have to be converted to one of the newer refrigerants. By the time you do that, and by the other parts you will need, like brackets and hoses, I think you are spinning your wheels. Plus - do want to hang just anything under your dash just because it's cheap? :mad:
#173611 05/31/2005 1:08 AM
Not that the rest still wouldn't be a pain, but a drop- in replacement for R-12 is available. It is compatible with the old oil in the system. Just evacuate (recover) and re-charge.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#173612 06/01/2005 4:17 AM
Thats what I was thinking.. when my wifes 95 Fjord Exploder AC went the way of all sinners, I bagged a kit from walmart for under $30 and a seperate can of some AC stop leak stuff. I hit it with the stop leak then the new stuff, and the AC has been blowing artic cold for two years now.
Same story with my '91 Jimmy and several friends older cars. The "conversion" is nothing more than an adapter that just screws on to the old fitting.
#173613 06/01/2005 4:33 PM
I have been toying with making a small water chiller and simply using the existing heater core as a chilled water coil. I (almost) never need heat.
#173614 06/01/2005 5:30 PM
LT Offline
Train Driver, that sounds like an interesting idea. Can you provide more detail about what you were thinking?
#173615 06/01/2005 8:42 PM
Same basic system as a standard auto system. Instead of the evaporator in the cab, a small freon to water heat exchanger is placed in line. A water pump would be needed to circulate the water and the heater box would need work to manage the condensate. With the right valves, I think that even the heater would still work.
The A/C guy here at work is interested in trying it and has located the parts in A/C catalogs.
#173616 06/02/2005 10:32 PM
Riding in the Passing Lane
I used the factory compresser & brackets that went with the engine in my 1970. I got a Vintage- Air inside unit but wanted to use an underdash but there is not enough space between the dash & firewall on the 70. I got a condenser from the salvage yard & a helpful parts man from Carquest got the fittings & hose to make up the hoses. smile
1972 Chevy c10 Cheyenne Super
#173617 06/03/2005 2:25 AM
I don't really want to help hijack jones' thread, grin but train driver, if you and your buddy get the idea working, take lots of pictures, write it up, and submit it as a Tech Tip. Now, back to jones' query. grin
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#173618 06/03/2005 10:34 AM
I installed an Old Air Hurricane unit in my '54 ... much less money than Vintage, and (other than prices) I can't see any differences between the two. After 2 years, I'm very happy with it!
And then, there's always the cheaper/easier under-the-dash units that you can buy anywhere - like at JEGS -- that I replaced in my truck:
See A Picture of Both Here
You can view all the notes on my install Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
