2 members (Steveoreno, TPR57C), 106 guests, and 4 robots.
Topics128,186
Posts1,057,320
Members48,469
Junior Member
Junior Member
I am waking up a 64 K10 fromm a several winters nap, and want to change all the fluids, what type of goo goes in the T case and 4 speed tranny? I have had the wrong lube cause a ceased tranny in an S10 is the only reason i ask. thanks for the help.
90w gear lube (usually marked "universal" or "multi-purpose") is specified for both your SM420 4 speed and Rockwell transfer case. That's another nice thing about our older trucks....90w is used in the transmission, transfer case, both axles, and the front axle joints. In the 70's they started the confusing habit of specifying 30w motor oil and ATF in some models.
