4 members (mk72, Hawkman, Wally / Montana, Gib70), 94 guests, and 2 robots.
Topics128,052
Posts1,055,774
#172983 02/05/2005 2:02 PM
when i got my 42 all the wireing is shot the man said it ran so before i pull it apart and off the frame i would like to start it what needs to be hooked up to get it to start. i have 3 boat 12v batterys on the shelf and do not want to buy a 6v for this task .ideas??????????? all i have in side right now is the frame motor tranny and rear .
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#172984 02/05/2005 2:57 PM
Riding in the Passing Lane
Get an ignition resister used on old mopars with points or late 50s chev. Disconnect wire on coil going to ignition switch & hook awire from resister to coil. Run good booster cables to starter & ground. Run a fuel line from pump inlet to fresh can of gas. Connect a wire from resistor to positive cable & start engine. smile
1972 Chevy c10 Cheyenne Super
