8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC), 104 guests, and 1 robot.
Topics128,060
Posts1,055,838
Members48,427
Junior Member
Junior Member
I am swapping cabs on my 1955 second series. What is the easiest way to disconnect the steering column, so I can remove the old cab and install the new one? Also does anyone have any advice on installing a brake master cylinder on the firewall? Thanks for the advice, I appreciate it.
Clark Thomas
not easiest , but only way is to unbolt the steering box and remove from below b4 removing the cab - can't say about moving the mc to firewall, but there's easy ways to update mc in stock position
Anonymous
Unregistered
Anonymous
Unregistered
You can also remove the steering wheel and shifter arm then lift the cab over the steering column. You have to be pretty tall to do this or have a tall lift.
Industrial chassis makes a kit for converting to firewall mount pedals. Kit is very well done and not cheap. I used one for my 53 and it fits perfectly. You can also find hanging pedals from junk yard donor and modify them to fit. I didn't want to screw around with mix/match/cut/fab so I just bought the kit...........
'53 chevy 3/4 ton
I dont know what you have in mind.Single master cyl,or dual.On my 55 2nd I bought the dual power unit that mounts right where the original was ,under the floor.Of course I have updated mine to front disc brakes.I got mine from Chevy Duty.
