| | | Forums66 Topics128,069 Posts1,055,890 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 12 Junior Member | | Junior Member Joined: Jan 2005 Posts: 12 | I am swapping cabs on my 1955 second series. What is the easiest way to disconnect the steering column, so I can remove the old cab and install the new one? Also does anyone have any advice on installing a brake master cylinder on the firewall? Thanks for the advice, I appreciate it. Clark Thomas | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not easiest , but only way is to unbolt the steering box and remove from below b4 removing the cab - can't say about moving the mc to firewall, but there's easy ways to update mc in stock position
Bill | | | | | | Anonymous Unregistered | | Anonymous Unregistered | You can also remove the steering wheel and shifter arm then lift the cab over the steering column. You have to be pretty tall to do this or have a tall lift. | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | Industrial chassis makes a kit for converting to firewall mount pedals. Kit is very well done and not cheap. I used one for my 53 and it fits perfectly. You can also find hanging pedals from junk yard donor and modify them to fit. I didn't want to screw around with mix/match/cut/fab so I just bought the kit...........
'53 chevy 3/4 ton
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I dont know what you have in mind.Single master cyl,or dual.On my 55 2nd I bought the dual power unit that mounts right where the original was ,under the floor.Of course I have updated mine to front disc brakes.I got mine from Chevy Duty. | | |
