| | | Forums66 Topics128,080 Posts1,055,950 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have seen the 73-87 1/2 ton IFS swap into the AD trucks but am curious if this swap will work for 55-59 Task Force trucks. I cannot locate anything on the web regarding this and was thinking the extra width of the task force might fit this wide IFS. Does anyone have any input on this? | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Thanks Norse. I am wanting to keep the original frame and am wondering if the 73-up front suspension crossmember can be installed to the original Task Force frame. Does anyone have the width dimension for the 55-59 frame at the front axle? | | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | IIRC the outside to outside width of the frame is 34" - but I'm a long ways away from my manual....
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
| | | | | Joined: Aug 2004 Posts: 47 Member | | Member Joined: Aug 2004 Posts: 47 | Outside of the frame at the front for the 3100 models in 1957 is 34.000" | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Thanks. There is a 73 crossmember in a salvage yard on the way home. I will stop and measure that to see if it is close. | | |
