2 members (walter74, 1 invisible),
102
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | Im having trouble figuring out how to disconect the column from the steering box. any ideas? Geo. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | gelee - I think that your column is like my 46. It is not supposed to come off the steering box. The whole thing comes out as a unit. You'll need to remove the pitman arm, unbolt the steering box from the frame and remove through the cab. Hope this helps George | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | 46 is right The two boxes are simular except that 46's got bearings and 40 has bushes I think.....it's been soooooooo long | | | | | Joined: Aug 2004 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 56 | Thanks, that explains a few things. Geo | | |
