2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the 50's car stuff does work - I can testify they'd fit on a 55-59, and as the shoes and cyls are the same on yers as mine, I'd expect all ya need are the hubs and drums to make that switch - if the drums are useable that package is well worth 50!!
Bill | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If they are early 50's car stuff they will work.
You'll end up using the truck inner bearing and the car outer, or maybe its the other way around, its been a while since I last did this.
You may need to redrill the holes in the backing plates to fit the axle, and you'll need to space the backing plates (very securely!) to make sure the shoes are located correctly to fit the drums. Keep the spacers you remove as you remove the stock backing plates, and use them as a pattern for diameter and thickness and then measure to determine the correct length.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | you know you gotta change axles or have yours redrilled for the 5 lug pattern. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Your replies are why I am so glad to be a member here. Your input over the last few days has been awesome.
I believe I am just going to wait and keep the original axle up front and eventually change over to disc conversion and dual master cylinder.
Thanks everyone.
Chris
Chris 1955FirstSeries
