5 members (TooMany2count, UtahYork, Gdads51, Rich'sToys, jasrking), 137 guests, and 1 robot.
Topics128,126
Posts1,056,354
Members48,441
#171929 03/08/2005 7:48 PM
hi all
would a half ton front axle from a 55 fit on a 3/4 ton 52? is there a width difference? spring spacing difference? leaf dimension difference?
the reason i ask is there is one available (condition unknown) locally drum to drum that would make a front disk brake swap easy for my 3/4 ton.
thanks
-bryan
#171930 03/10/2005 3:00 AM
frown
According to the Chevrolet Master Parts Catalog, they will not interchange.
#171931 03/10/2005 3:32 AM
Quote
Is the '55 a '55 1st?
If its a '55 1st I think you can make it work. It might be easier if you also grab the springs from the 1/2-ton also.
#171932 03/10/2005 5:23 PM
i don't know the difference between a 55 first and anything else. all i've seen of the axle is the picture i found on the 'net
#171933 03/10/2005 5:24 PM
Quote
Originally posted by 6cylindersovertexas:
frown
this makes sense, since i'm after the ability to swap on one of the aftermarket disk brake setups that aren't available for my 3/4 ton.
#171934 03/10/2005 6:02 PM
Quote
'55 1st is the same basic design as your '52. The later '55, often just called '55, is a newer design and the axle is probably just enough different to make your proposed modification difficult.
I have a '54 front axle laying in my yard unused, and I'd bet lots of guys who are swapping to an IFS would be happy to have you haul off a '47 to '55 1st 1/2-ton axle that is likely to work the way you want.
#171935 03/10/2005 7:47 PM
just got an email from the seller, it's a 2nd series and the springs are 32" apart. i'll have to go measure mine.
#171936 03/10/2005 7:52 PM
Quote
Originally posted by OldSub:
... I'd bet lots of guys who are swapping to an IFS would be happy to have you haul off a '47 to '55 1st 1/2-ton axle that is likely to work the way you want.
from the pic that looks like what happened. complete axle, drum to drum with springs
