| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | hi all
would a half ton front axle from a 55 fit on a 3/4 ton 52? is there a width difference? spring spacing difference? leaf dimension difference?
the reason i ask is there is one available (condition unknown) locally drum to drum that would make a front disk brake swap easy for my 3/4 ton.
thanks -bryan | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | According to the Chevrolet Master Parts Catalog, they will not interchange.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by baldredhead: would a half ton front axle from a 55 fit on a 3/4 ton 52? is there a width difference? spring spacing difference? leaf dimension difference? Is the '55 a '55 1st? If its a '55 1st I think you can make it work. It might be easier if you also grab the springs from the 1/2-ton also.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | i don't know the difference between a 55 first and anything else. all i've seen of the axle is the picture i found on the 'net | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | Originally posted by 6cylindersovertexas: According to the Chevrolet Master Parts Catalog, they will not interchange.this makes sense, since i'm after the ability to swap on one of the aftermarket disk brake setups that aren't available for my 3/4 ton. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by baldredhead: i don't know the difference between a 55 first and anything else. all i've seen of the axle is the picture i found on the 'net '55 1st is the same basic design as your '52. The later '55, often just called '55, is a newer design and the axle is probably just enough different to make your proposed modification difficult. I have a '54 front axle laying in my yard unused, and I'd bet lots of guys who are swapping to an IFS would be happy to have you haul off a '47 to '55 1st 1/2-ton axle that is likely to work the way you want.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | just got an email from the seller, it's a 2nd series and the springs are 32" apart. i'll have to go measure mine. | | | | | Joined: Feb 2005 Posts: 81 Member | | Member Joined: Feb 2005 Posts: 81 | Originally posted by OldSub: ... I'd bet lots of guys who are swapping to an IFS would be happy to have you haul off a '47 to '55 1st 1/2-ton axle that is likely to work the way you want. from the pic that looks like what happened. complete axle, drum to drum with springs | | |
