1 members (klhansen),
90
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I was at a swap meet this weekend and was talking trucks with a guy when he told me about adjusting the rear of the hood on an AD truck so it would not bow from side to side. He told me that an older gent had showed him that the inner brace on the rear of the hood itself could be loosened up and adjusted as needed , anyone else heard of this trick? | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | This information is available in the factory shop service manual for the A D trucks. It's not a trick it works. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | hmm, will have to try it....thanks | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I finally used the "au contraire" method of adjusting the hood on my '48.
After several attempts of holding it down with a stack of firewood on it and tightening the bolts from inside the cab, I pressed the hood up against the hinges with a broom resting on the bumper. I then tightened the bolts on the inside. It worked pretty well. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | Hey , I always enjoy talking trucks with people , I learn something new everyday. Now if I could just line up my darn doors! | | |
