7 members (Gdads51, texas46, Otto Skorzeny, TUTS 59, Ponchogl, klhansen, greenie-reddy), 136 guests, and 4 robots.
Topics128,266
Posts1,058,385
Members48,485
I am searching high and low for two window parts for my 51 gmc 1/2 ton.I think the parts are called sashes, but Im not sure. I have searched BT bits, ChevyDuty, Ricos, you name it. They are the channels that the side windows sit in. Do any
of ya'll know where I can find a pair of these and is that the correct name for these critters. Thanks much in advance.
jimmy - they're called window channels [felt] - try the site sponser at the top of the page - American Classic - or look at other places from the 'bolt links page using the right name! grin
Check out your local glass shop. There are supply catalogs for that trade that show multiple varieties of channel. They may not have spot on replacements but more than likely a generic that can work every bit as well......
Hey guys, thanks for the input. I probubly didn't do a very good job of describing the parts to ya. MY bad. But, Bowtie bits emailed me back and informed me they are sashes. The very bottom of the window is what sits in these. They have them as a used part, so if anyone else is needing that info, this will clear that up. Thanks so much gang. (gotta get me a service manual)
