8 members (KEVINSKI, Charles in CA, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln, ShopRag, Gray_Ghost, Peggy M),
188
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | I am searching high and low for two window parts for my 51 gmc 1/2 ton.I think the parts are called sashes, but Im not sure. I have searched BT bits, ChevyDuty, Ricos, you name it. They are the channels that the side windows sit in. Do any of ya'll know where I can find a pair of these and is that the correct name for these critters. Thanks much in advance. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | jimmy - they're called window channels [felt] - try the site sponser at the top of the page - American Classic - or look at other places from the 'bolt links page using the right name! Bill | | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | Check out your local glass shop. There are supply catalogs for that trade that show multiple varieties of channel. They may not have spot on replacements but more than likely a generic that can work every bit as well...... | | | | | Joined: Jun 2004 Posts: 73 Member | | Member Joined: Jun 2004 Posts: 73 | Hey guys, thanks for the input. I probubly didn't do a very good job of describing the parts to ya. MY bad. But, Bowtie bits emailed me back and informed me they are sashes. The very bottom of the window is what sits in these. They have them as a used part, so if anyone else is needing that info, this will clear that up. Thanks so much gang. (gotta get me a service manual) | | |
