0 members (),
120
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | I've pulled the front end on my 1940 1/2 ton.
The brake drums are frozen on.
Any advice on getting them off?
I'm thinking of cutting through the drums and then removing the brakes. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Have you tried backing the brake shoes off? Pop the little covers off. Back off the adjustment wheels..if you can....a few whacks with a BFH to get the rust moving around...soak with stuff like PB blaster...leave it soak for a couple of hours, work on the other end of the truck...repeat....Unless they are one solid ball of rust, they should come off....I would not cut the drums quite yet...both my trucks had the same problem...the drums came off all 4 corners...both trucks.... | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Do the wheels turn ? If so, why not undo the wheel bearings and pull the hub and drum off as one. If there is a ridge that interferes, you can attach a chain to two or three studs and use a heavy bar to yank it free. If the drums are reuseable and you need to have them machined, they will want them mounted on the hubs, to turn them. | | | | | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | b'laster first. let soak for a few hours, then squirt on some more. pray to the great god thor for guidance---then knock the hell out of the drum with a baby sledge.
usually works.
wear safety glasses
relieves stress
if it don't work you will get tired enough to go nap and forget it. | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Wheels won't even budge.
I haven't been able to back the shoes off with the adjustment wheel.
I'll try more brute force. Maybe soaking for a week will help. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Before you cut the drums maybe you could try removing the backing plates? Then soak the whole mess? Just a crazy idea...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Perseverance. Remove the nut and wheel bearing. Try putting one or two flat bars between the drum and backing plate and apply pressure while you tap around the brake drum. You can fracture the drum if you hit it too hard. Hammer and wood block are good. A friend to help, also good. Use one or two lug bolts screwed in the drum and a long pry bar to rotate the drum. Brake drums from 36-50 will fit your truck BTW. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the axle is off the truck, this to me would be a distinct disadvantage.However, if you can be sure that you can buy those drums new, then sacrificing the drums may be the answer. That is tough that they won't turn. If you are doing a restore, you will want to protect the rest of it, backing plates etc. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Those drums are not reproduced to my knowledge. Backing plates may be easier to obtain than the drums although there are alot of drums out there. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Anybody know what kind of brakes these are? If they are the Huck style, unbolting the wheel cylinders can help unstick the wheels. | | | | | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | I had the same problem with my son's '62. We got a lot of good advice here. Eventually we got the drums off without cutting! IIRC, one poster even recommended a blow torch. I don't remember who that was. It was over a year ago. But I'm pretty sure he claimed that heating the drum had worked for him....
I'd try almost anything else before destroying those drums. Looks like all the other bases have been covered.
Then you will know the truth, and the truth will set you free.
- Jesus -
| | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | PB Blaster and a gear pller worked on one. Now we'll see about the other.
Thanks for the advice | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | On a '57 2-ton I bought the left front drum had been sitting on the ground for so long the ground was above the adjuster hole. I ended up cutting a hole in the backing plate and cutting the adjuster out. | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | InMy40s in on the right track. Had the same problem before. Borrowed my brother in laws three prong drum puller and turned the handle and popped them off (maybe it was a gear puller but it fit the drums perfectly) | | | | | Joined: Jul 2003 Posts: 85 Member | | Member Joined: Jul 2003 Posts: 85 | I heated around the outside of the drum with an acetylene torch, removed the bolts on the wheel cylinder and rotated the cylinder inside the backing. then I attached the wheel ring back on with a couple of studs (not the whole wheel, just the little donut shaped peice) and used a 4 foot 1 inch solid steel pry bar to move it all around.
took about 2 days, and 3 heatings (not to red hot, just make it hotter than the rest of the truck) expansion will break the rust bond.
since the axle is out fo the truck, you may want to pin it down with something really heavy while you futz with it. so that all your force is going into the drum and not into wobbling the axle about.
-Mike R. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | After working on some old outboard motors, some from salt water use, I'd agree that lots and lots of heat is the way to go. And make sure the brake adjustment is backed off. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Nov 2004 Posts: 24 Apprentice | | Apprentice Joined: Nov 2004 Posts: 24 | thats funny well at least it wasn't just me i used a can of pb blaster and a gear puller and i was even able to get my brakes to back off had even more fun and a bfh to get the rears off.
1940 1/2 ton chevy
| | | | | Joined: Sep 2004 Posts: 74 Member | | Member Joined: Sep 2004 Posts: 74 | use a big crowbar (I went with one with a flat end and about 3' length) and start trying to break it loose. Once it comes loose, if you can't back it off, use a BFH.
I am not bound to please thee with my answers. - William Shakespeare 1967 C10 1983 Olds Delta 88
