2 members (delwrench, Gray_Ghost), 114 guests, and 1 robot.
Topics128,176
Posts1,057,058
Members48,460
This has been discussed recently but here's a shot of my gasket showing the darkened ends where it is leaking as compared to the still shinny silver area towards the center. To me either I have the exhaust manifold machined flat or replace the guide pin with a bolt.
http://community.webshots.com/photo/127846177/127846450zvjGex
Just trying to tighten things up here and there.
Craig
I still think that Chevrolet didn't finish the job on exhaust manifolds. The guide pin is great for installing the exhaust manifold, but after everything is in place and snugged up, I think the guide pin should be removed and a bolt put in it's place to tighten the ends of the manifold. This may not be so much the case with a one piece manifold, but especially the case with a two piece set of headers.
Did you try to loosen the two end bolts? They may be over tightened. I don't have the torque specs handy. On the 250 and 292 the two outside bolts are 20# and the center bolts are 30#
Tube header flanges are simply too weak to be clamped without replacing the guide pin with a stud. It's real easy to get leaks from over tightening tube headers. At least it is when you replace all the bolts and pins with studs/nuts(w/fine treads).
'67 GMC 3/4 292 4spd
My cure is to take the manifolds off and clean the surfaces. With new gaskets, put a coat of ultra-copper Rtv on both sides. Assemble, tighten, and let sit for 24 hours to cure before starting. Trim off the excess with a knife. Replacing the pin with a bolt does help.
Fred
52 3600
69 C-10
I had a serious exhaust leak with my 235 before I had the head work done, I had napa remove the studs and replace with bolts, it looks alot better I think, and now I hopefully wont ever have to worry about another exhaust leak
Craig,
I have a NORS exhaust manifold gasket and it is approximately twice as thick as modern replacements. Try two gaskets and use the copper RTV on all sides of the doubled-up gaskets.
This would work with either the original alignment studs or with studs replaced with bolts.
Tim
Pal Offline
what the heck. I'll try any cheap answer. My exhaust gasket has never sealed right.
35 + years of rollin' steel!
