4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
Well folks, it's a whole new ball game. Just bought a \'54 GMC 100 and have LOTS of questions on the fix 'em up. Just call me a blind, stupid newbie!
A buddy says that I can replace the leaking main seal with a rope gasket, pulling the cover from underneath and fishing it around rather than having to remove the engine and pull the cam. Sounded too good to be true, but tell me more--is it so?!!?
As always, I appreciate your insight in advance! Cheers!
YES!
There are kits available to remove and install the rear main seal cool
The trick is getting the seal installed properly in the tight space you are going to have to work in.
Patience,,,patience,,,patience grin
Thanks Luke! Great news!
Which particular parts house sells these?
