9 members (TooMany2count, Opelika Tom, Otto Skorzeny, 78buckshot, TrknGMC, Charles in CA, MikeE, Wayne67vert, TexasA&M48Truck), 59 guests, and 0 robots.
Topics128,091
Posts1,056,037
Members48,433
#171146 03/23/2005 2:12 AM
Can someone describe how the parking brake cables attach to the rotating tube mechanism on my truck?
(53 3/4 ton chevy). I don't have the piece to connect threaded cable end to the plate on end of tube. I'm planning to just make a couple turnbuckles to connect 'em....... unless someone has another suggestion. Just to verify, I'm talking about the cables which go to each rear wheel, not the one from front of cab. Advice appreciated
'53 chevy 3/4 ton
#171147 03/23/2005 2:41 AM
X
X Offline
The cables connect to the cross shaft lever with a clevis. See here for Jim Carter part #ME160. I think this is the part you are looking for if I understand you correctly.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#171148 03/23/2005 3:34 AM
hmmm.......... must be the cables I have are for shorter wheelbase truck....... about 6 inches too short!!! I bought the truck frame with cables already installed, so PO must have used the wrong ones. Rather than buying new new cables, I think I'll make an extension piece. Thanks for your help........
'53 chevy 3/4 ton
