4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#170898 03/08/2005 10:39 PM
im gonna be doing an alternator conversion on my 1961 chevy apache with a 235 and itl have to power along with everything else, a speaker and sub system of high power.. someone suggested 100 amps rating.. but i saw a 200 recently and i wonder.. can i have too much power?
#170899 03/09/2005 1:13 AM
Moderator
Moderator
Just remember, it takes horsepower to turn those. The more amps, the more HP.
Don't lose your head to save a minute,
You need your head, your brains are in it.
Burma-Shave (1947)
#170900 03/09/2005 2:07 AM
100 should be fine. 200 would probably be for a world-class stereo setup...and very expensive.
1954 GMC De Luxe COE
#170901 03/09/2005 5:22 AM
i read an article about alternators and as it seems the more amps you have the hotter the alt. gets and the more difficult it is too cool it. heat is what kills alternators, so a 200 amp alt would hev to be very well engineered and built, which costs money, and i think it would be WAY overkill.
1948 3600 thriftmaster
#170902 03/09/2005 5:25 AM
There is a very informative discussion going on in www.mychevytruck.com forums regarding optima batteries, amps, subwoofers and alternators and the power it takes to run all that high draw stereo equipment.
Gravity - It's not just a good idea, it's the law.
#170903 03/09/2005 5:58 AM
i would go whith the 100 amp and add a secound battery on your other fender well then you would have power to spare
