1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#170484 12/15/2004 1:44 AM
I've been wanting to do this for some time. I hope that 10 seconds of a wav sound file isn't too long. I'll pare it down if necessary. I'm on a phone line myself.
First, here's a picture of my 261 taken last spring.
My 261
Here's it starting (6 volts!). It runs so quitely that you can only hear fan and belt noise. The microphone was near the distributor.
261 Starts and Runs
I put the microphone down the breather tube. Don't tell me that you hear something, like that doink-doink, that says it's going to blow up. I want to be surprised!
261 Sounds from the Breather Tube
Here's the sound from inside the valve cover.
261 Sounds from Inside the Valve Cover
For you engineers: How about a Fourier transform to determine the individual frequencies?
#170485 12/15/2004 1:51 AM
Number 3 intake is too tight,maybe #5 too
#170486 12/15/2004 3:24 PM
Sounds great!!!
#170487 12/15/2004 4:21 PM
I swear that I could hear some imported metal in there, somewhere.
Very cool post !!!
1951 1 Ton Completed
#170488 12/15/2004 8:36 PM
Now THAT was one neat post! grin
#170489 12/15/2004 9:39 PM
Wally: I am impressed!! popcorn The Truth is Out There (Also jealous)
#170490 12/16/2004 1:27 AM
Very cool!
First wav file - your starter bearings need lube or your brushes and armature need dressing.
Second wave file - You can actually hear the sound of air displacing in the crankcase between cylinders as pistons reciprocate. Would be much better with a PVC system vented to the intake manifold.
Third wave file - is this after a thorough warm up?
Your microphone would make a good internet diagnostic tool!
Life's short - don't waste it.
#170491 12/16/2004 4:22 PM
I suppose there is some diagnostic value. I wish I had recorded my old 235 with it's broken ring and scored cylinder from the breather tube. It was warmed up on only a 3-mile drive from work, but that was a guess, right?
The lifters came from Patrick's in Arizona. Does that count as imported?
#170492 12/18/2004 8:47 PM
Big Bolt Shop Curmudgeon
I take my hat off to you!
The unmistakeable sound of a stovebolt being cranked up and running quietly is just warms the cockles of my heart. grin
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#170493 12/22/2004 4:12 PM
Thanks! Making a wav sound file is easier than a jpeg. $10 for a microphone and you can record directly to your PC using the Sound Recorder that is already installed. It helps to use a laptop!
There's the same old problem of getting the file on a host with its own URL. I used a web site that another fellow and I already had. Will Web Shots host wav files?
