| | | Forums66 Topics128,154 Posts1,056,851 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 21 Junior Member | | Junior Member Joined: Nov 2004 Posts: 21 | I am new to restoring and need advice. i would like to replace the rocker panels on my 63 fleetside and am not sure how they come off. Are thaey spot welded or is it just the four bolts from the under side? I am not a welder so this might be beyond by abilities. Thanks for your hilp
Thanks, Ivor
63 chevy short/fleet 292/4speed under construction
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The rocker panels are spot welded on both ends where they meet the door posts on the hinge side and the strike side. Additionally, they are welded on the underside. Many times, the rockers are so badly rusted that it is very difficult to determine the attachment method.
I would never discourage someone from tackling a task, however there is some welding required to properly install new rockers. Additionally, removing the old rockers may require some cutting wheel work and/or plasma cutting, depending on the condition of the old rockers. When replacing rockers, make sure to have the new pieces prior to removing the old. You want to make sure you have enough material to reattach the new units.
Best of luck. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | There are quite a few spot welds, they are best removed w/slow drill & spot weld cutter. Look like a small dimple in the metal near the ends/edges. Rockers need to be spot welded back on, easy job for a welder, really need a MIG. Drill or punch holes in new rocker in same # of places the old one was attached with, then simply fill holes w/weld. Keep clamped tight w/screws,Vise-grips whatever. I left mine bolted to frame & did one side at a time to prevent any movement while/as rockers are removed. Brian | | |
