2 members (Peggy M, Gray_Ghost), 184 guests, and 1 robot.
Topics128,089
Posts1,056,116
Members48,434
#17011 01/14/2002 9:56 PM
Where can I get a rebuild kit for my 56-235? I also would like to find a source for a Corvette cam for this engine.
Times are changing-By Bob Dylan
Cindy in Oregon
1945 GMC COE Victory Truck 5ton COE- NOT FOR SALE
1955 Chevy First series 5 window p/u
1947 Antique Husband only series
#17012 01/14/2002 11:20 PM
Patrick's (in the links section) can sell you everything you need. He is THE expert on cams, too.
Fred
52 3600
69 C-10
#17013 01/16/2002 6:27 PM
None of these engine parts are obsolete. Your local automotive machine shop can usually beat any restoration catalog supplier
prices.
Note; you are looking for a shop equipped to bore, turn cranks, etc since you're likely to need this service anyway--they usually give you jobber's price if you have them do necessary machine work. I can tell you that you're looking at a minimum of $900 to $1100 for a rebuild and that's assuming you use your old cam and lifters and assembling yourself. These old stovebolts aren't cheap to rebuild!
#17014 01/17/2002 3:32 AM
Patrick's. The Corvette 235 and all 261's used the same cam specs which are nearly identical to the Howard M4 camshaft which is sold by Patrick's also, as well as many other Chevy truck parts suppliers.
#17015 01/17/2002 3:35 AM
yea, they are not cheap... that is exactly why I'm not going with a 235 anymore.
May the force be with you - SoloWookie
solowookie.com
