| | | Forums66 Topics128,078 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17011 01/14/2002 9:56 PM | Joined: Mar 2001 Posts: 21 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 21 | Where can I get a rebuild kit for my 56-235? I also would like to find a source for a Corvette cam for this engine.
Times are changing-By Bob Dylan Cindy in Oregon 1945 GMC COE Victory Truck 5ton COE- NOT FOR SALE 1955 Chevy First series 5 window p/u
1947 Antique Husband only series
#17012 01/14/2002 11:20 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Patrick's (in the links section) can sell you everything you need. He is THE expert on cams, too.
Fred 52 3600 69 C-10
#17013 01/16/2002 6:27 PM | Joined: Oct 2001 Posts: 36 Member | | Member Joined: Oct 2001 Posts: 36 | None of these engine parts are obsolete. Your local automotive machine shop can usually beat any restoration catalog supplier prices. Note; you are looking for a shop equipped to bore, turn cranks, etc since you're likely to need this service anyway--they usually give you jobber's price if you have them do necessary machine work. I can tell you that you're looking at a minimum of $900 to $1100 for a rebuild and that's assuming you use your old cam and lifters and assembling yourself. These old stovebolts aren't cheap to rebuild! | | |
#17014 01/17/2002 3:32 AM | Joined: Nov 2000 Posts: 45 Member | | Member Joined: Nov 2000 Posts: 45 | Patrick's. The Corvette 235 and all 261's used the same cam specs which are nearly identical to the Howard M4 camshaft which is sold by Patrick's also, as well as many other Chevy truck parts suppliers. | | |
#17015 01/17/2002 3:35 AM | Joined: Oct 2001 Posts: 198 Member | | Member Joined: Oct 2001 Posts: 198 | yea, they are not cheap... that is exactly why I'm not going with a 235 anymore. | | |
